Save DVR recordings to custom libraries
Server Version#: 1.29.1.6316
Tuner Make/Model: HD home run connect
Guide/Lineup name:
Using XMLTV?:
Channel number/Name:
I would like to record sports to custom sports folders. Ie sports or football. However when I go to setup the recording the list is pre-populated with what plex thinks it should be (TV shows). While this is technically correct it’s going to require me to move media to the correct physical storage folder .
Is there a way to designate it to save to a custom library?
@cveile
The list is not populated by what Plex thinks, but with what libraries you have created. So all you have to do is create the sports libraries you want then you can pick those when you setup the recording.
