Scanner not updating metadata or posters
Trying to refresh incorrect metadata, even if I match it, the poster and metadata remain incorrect
I’ve just imported a large number of files, and have been trying to get the duplicates merged, and didn’t realise that when you are in merge mode, it keeps the first merge item selected - so I accidentally ended up with 21 movies under the same title - all of them are now still keeping the same metadata and poster.
Imgur
What was weird was that when importing originally, it would correctly match the poster, but not the name - it was showing the file name - I changed the order of the agents in the list, so move local information to the bottom of the list, but now I’m unable to match the modified items - I just get a spinning circle…
Imgur
I do see some errors in the log, so is that suggesting there’s an issue with my metadata package locally, or is it a remote issue?
Server Version#:1.19.4.2135
Player Version#:4.36.1
All I can say is correct naming.
They are correctly named… as you can see from the screenshot.
The folder and file name must be the same except for the extension…
/Movies
   /Avatar (2009)
      Avatar (2009).mkv
   /Batman Begins (2005)
      Batman Begins (2005).mp4
But you know best
It is… the movie simply has the format appended to the end for disambiguation.
That’s never been a problem before now.
No need to be snarky
Naming never a problem till it is, snarky no but the naming is not correct. As i said it’s up too you
It appears to be because it’s in a collection -
If I manually match now after disabling collections, the correct match is displayed and the poster is updated.
I haven’t needed to touch the naming of the files.
