Hello. I have had a problem. when I scan for music goes fine the first couple of hours to add music. after it stops. it just stands and spins. but nothing happens. I have tried to restart and optimize the database. and restart the scan. but it is not helping. How can I see if something still happens? hope someone can help me further.
hi trumpy81. I have a lot of disk space left. I will try to delete plex and reinstall it which log should I look in to see if it repeats itself? The plex folder fills 15.62 GB I’m quite right that the plex does not run so well on my synology nas.
thank you
/Sascha
Now I have deleted plex and removed the user as well as folder in shared folders. and SSH to my nas and look for if I could find plex the locations Q11 refers. but no plex folder found. am I so ready to install the plex again?
thank you
/ Sascha
Hello. then I have had the same problem again. as we talked about lately. then I had deleted everything and reinstalled. but now it has stopped again. I attach the new logs. plex folder fills 4.99 gb.
