Scanning TV Shows
How do I stop Plex scanning content during the day, I have it set to scan after 1am
Disable automatic and periodic library scans.
https://support.plex.tv/articles/200289526-library/
Instead, enable library scans as part of the scheduled tasks. Set their time window as you see fit – but it should be when your server is typically not busy with playback.
https://support.plex.tv/articles/201553286-scheduled-tasks/
Thanks, I’ll check it out
Do you mean disable “Refresh library metadata periodically”
Yes, both automatically and periodically.
