Scanning with Plex Media Scanner.exe always crashes for movies
Server Version#: 1.23.3.4707-ebb5fe9f3
Player Version#: n/a
For all versions of the server for the past 6 weeks or so, using the Plex Media Scanner.exe method to scan a single directly into my library hasn’t been functional. If a do a full library scan, it works without a hitch but I have a large library and only want to update when a new item is added. I found the automatic scanning to constantly be updating folders that are unchanged so switched to this.
I always update with a command like the one below and get a crash report which is sent to Plex but I don’t see how I can read that report in the folder. The logs even with verbose/debug turned on don’t seem to show why it crashed, just that it was scanning the folder and then a crash report sent. Any thoughts? It works fine with TV shows and I’m using the new movie agent.
"C:\Program Files (x86)\Plex\Plex Media Server\Plex Media Scanner.exe" --scan --refresh --section 25 --progress --directory "G:\MOVIENAME\"
****** PLEX MEDIA SCANNER CRASHED, CRASH REPORT WRITTEN: 463Xf2c8
Jul 02, 2021 10:29:08.993 [25932] DEBUG - [JobRunner] Job running: "C:\Program Files (x86)\Plex\Plex Media Server\CrashUploader.exe" "--directory=D:\Plex\Plex Media Server\Crash Reports\1.23.3.4707-ebb5fe9f3" --version=1.23.3.4707-ebb5fe9f3 --platform=Windows "--platformVersion=6.2 (Build 9200)" --serverUuid= XX --userId=XX --sentryUrl=https://sentry.io/api/1233455/minidump --sentryKey=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx --vendor=Microsoft --model=x64 --device=PC --allowRetries=0
