Scheduled Shows Not Recording
Seemingly random shows I have scheduled to record are not being recorded or the recording is being cut short before it’s finished.
When searching though my logs, note the following shows.
  1. Svengoolie: Did not record. I even went so far as to double check the PLEX guide and saw that the show was being recorded while airing. Later the file doesn’t exist.
  2. Wonder Woman: Only the first 10 minutes of this show were recorded.
Again, to be clear, some shows I’ve scheduled to record do so without incident. Others are not being recorded or are only partially recorded.
I have attached all my PLEX server logs to this forum post.
Below is my system and software information.
Server Version#: 1.18.4.2171-ac2afe5fe
Player Version#: 6.4 build 9
Breakout Box: Silicondust HDHomerun Duo
OS: Windows 10 version 1909 OS build 18363.592
Antenna: Monoprice Foldable Long Range HD8 Outdoor HDTV Antenna, 80 Mile Range: Product id 24172
ISP: AT&T Fiber. Fast.com test speed = 920Mbps
Computer Hardware:
CPU - Ryzen 9 3900X
Motherboard - ASRock X570 PHANTOM GAMING 4 AM4 AMD X570 SATA 6Gb/s ATX
Ram - CORSAIR Vengeance LPX 32GB (4 x 8GB) 288-Pin DDR4 SDRAM DDR4 3600
Video Card - ASUS GeForce RTX 2060 SUPER 8G EVO GDDR6 Dual-Fan Edition
Power Supply - Seasonic FOCUS PX-650, 650W 80+ Platinum
Hard Drive running OS and Plex server - Crucial P1 1TB 3D NAND NVMe PCIe M.2 SSD - CT1000P1SSD8 formatted as NTFS
Hard Drive recording to - WD Blue 2TB Desktop Hard Disk Drive - 5400 RPM SATA 6Gb/s 64MB Cache 3.5 Inch - WD20EZRZ formatted as NTFS
Case - Corsair Carbide Series 275R CC-9011133-WW White Steel / Plastic / Tempered Glass ATX Mid Tower Gaming Case
Plex Media Server Logs_2020-01-19_01-35-05.zip (5.8 MB)
I am having similar issues. The guide shows the OTA program is airing, and even have the red dots signifying it is scheduled to record. But in the DVR schedule, it is not listed. When the show actually airs, it does not record. I’m running PMS 1.18.5.2309 and I refreshed the guide manually. Windows with a Silicon Dust.
