I have seasons 1-6 of Scooby-Doo and Scrappy-Doo as listed on tvdb ID 78740
Plex only shows seasons 1-4
Using my Media Center Master software lists all seasons and episodes ok
It’s a naming issue.
… which is what ~80% of all similar cases as this one have as their cause.
So please tell use the folder structure and file names you are using.
Also important is, at which level of the folder hierarchy you have pointed Plex’s library (using the “Add Folders” property page).
Thanks for your prompt reply, I did the Plex Dance and all is fine now.
