Sdh in sub folder issue
Server Version#: Version 1.41.7.9823
Player Version#: all tested inc Version 1.109.0.329-ea562b95
Movie name (YEAR)/subs/English.eng.sdh.srt becomes the following >>>
Stream id=“894434” key=“/library/streams/894434” streamType=“3” canAutoSync=“0” codec=“srt” language=“Southern Kurdish” languageTag=“sdh” languageCode=“sdh” format=“srt” displayTitle=“Southern Kurdish” extendedDisplayTitle=“Southern Kurdish (SRT External)”
Plex DocumentationYour MediaAdding Local Subtitles to Your Media
Subtitles must have the same name as the movie.
Examples:
movie (year).mkv
movie (year).eng.sdh.srt
movie (year) [other info].mkv
movie (year) [other info].eng.sdh.srt
No but thx, it is not needed for subs folder and also thats not the issue. The issue is with sdh as XML extract shows >> Southern Kurdish. Using forced instead of sdh work as intended removing sdh works as intended this is a BUG with sdh in subs folder.
Suggest you rename per the Plex documentation, then refresh the metadata.
You may need to Plex Dance the movie.
M:\MOVIES\ENVY (2004)
|   Envy (2004).mkv
\---subs
        Envy (2004).eng.sdh.srt
        Envy (2004).eng.srt
Thx for extensive and detailed response. Following your suggestion it was possible to get it to work. But its not an quick and easy fix over many past folders, so I would like too end this discussion with flagging that the scanner needs a tweak so it can work just like …eng.forced.srt that always works flawlessly.
But thx for your time and for all future library entries ill make sure to do as you suggest.
Tiny Media Manager may be able to assist.
I’ve not tried it with a subs folder. It will correctly name external subtitles that are in the same folder as the movie.
Filebot or other tools may also work.
Snippet from another thread:
There are tools that can help. Here’s a shortlist. The free version of Tiny Media Manager works for most people.
Many people use Filebot. It is quite powerful and can rename an entire library in minutes.
Tiny Media Manager is also very useful, and free.
Example TMM Renamer Patterns:
  • Show Name: ${showTitle} (${showYear})
  • Season: Season ${seasonNr2}
  • Episode Name: ${showTitle} (${showYear}) s${seasonNr2}e${episodeNr2} ${episode.title}
  • Movie Name: ${title} (${year}) {imdb-${imdb}}
PowerRenamer in Microsoft Power Tools is helpful for simple renaming with pattern matches or regular expressions. It makes quick work of tasks such as adding a year to file names, removing undesirable text from multiple files, etc
I had exactly the same issue and I didn’t realise that it was caused by the need for identical naming. But as fordguy61 said, it is.
As an aside I do think it would be helpful to the community if the page about subs naming was as explicit as the response from fordguy61.
I used a simple batch script to change the names of the existing subs to the correct format, to clean my library up and it might be an option for you to do the same.
