Hello,
I try to add a english SRT subtitle to a couple of movies. They are named with either en.sdh or eng.sdh. Still they come out as Southern Kurdish in Plex…?
What am I doing wrong here?
Hello,
Which agent are you using for that library?
If you are using the Movie Database agent then the SDH flag will not work, see: https://support.plex.tv/articles/200471133-adding-local-subtitles-to-your-media/
Note : Support for SDH/CC subtitles requires Plex Media Server v1.20.3.3401 or newer. It also requires you to be using the newer Plex Movie metadata agent and not the older “Plex Movie (Legacy)” agent.
Your screenshot shows a movie that is definitely not matched with that agent as it clearly shows Rotten Tomatoes ratings which you won’t get with the TMDB agent.
If you want to use the SDH flag then you need to be using the “Plex Movie” agent, and make sure you refresh the metadata for those items.
Refresh Metadata of this movie. It should move it over to use the Plex Movie agent.
Verifiy it by looking at the Plex media info XML of that movie. (guid="plex://movie.... means it is using the new agent)
(If it doesn’t, you probably have moved to and fro agents too many times and your library is damaged.)
Ok,
I’ll check. I’ve never changed the agent at all, so I do not fear that…
Seem right to me?
<MediaContainer size="1" allowSync="1" identifier="com.plexapp.plugins.library" librarySectionID="16" librarySectionTitle="Filmer" librarySectionUUID="e4473c41-f0db-419c-af69-b68fa1b02366" mediaTagPrefix="/system/bundle/media/flags/" mediaTagVersion="1673372551">
<Video ratingKey="156142" key="/library/metadata/156142" **guid="plex://movie/5d7770cbfb0d55001f5f9123"** studio="Mark Stewart Productions Ltd" type="movie" title="Armstrong" librarySectionTitle="Filmer" librarySectionID="16" librarySectionKey="/library/sections/16" summary="Dramatic, moving and deeply human, ARMSTRONG offers the definitive life story of Neil Armstrong: from his childhood in Ohio to his first steps on the Moon, and beyond." rating="7.5" audienceRating="7.4" year="2019" tagline="The mission you know. The man you don't." thumb="/library/metadata/156142/thumb/1674651062" art="/library/metadata/156142/art/1674651062" duration="6004957" originallyAvailableAt="2019-07-12" addedAt="1674595604" updatedAt="1674651062" audienceRatingImage="rottentomatoes://image.rating.upright" chapterSource="media" primaryExtraKey="/library/metadata/156143" ratingImage="rottentomatoes://image.rating.ripe">
<Media id="184777" duration="6004957" bitrate="36243" width="1920" height="1080" aspectRatio="1.78" audioChannels="6" audioCodec="dca-ma" videoCodec="h264" videoResolution="1080" container="mkv" videoFrameRate="24p" audioProfile="ma" videoProfile="high">
<Part accessible="1" exists="1" id="186186" key="/library/parts/186186/1674566455/file.mkv" duration="6004957" file="/volume1/Media/Video/Filmer/Armstrong (2019)/Armstrong (2019).mkv" size="27207673565" audioProfile="ma" container="mkv" deepAnalysisVersion="6" requiredBandwidths="42727,41960,40684,38876,38419,38038,37528,37528" videoProfile="high">
Could you post a little more of it? Particularly the part where the video, audio, and subtitle streams are listed.
Sure ![]()
Here it is:
<Video ratingKey="156142" key="/library/metadata/156142" guid="plex://movie/5d7770cbfb0d55001f5f9123" studio="Mark Stewart Productions Ltd" type="movie" title="Armstrong" librarySectionTitle="Filmer" librarySectionID="16" librarySectionKey="/library/sections/16" summary="Dramatic, moving and deeply human, ARMSTRONG offers the definitive life story of Neil Armstrong: from his childhood in Ohio to his first steps on the Moon, and beyond." rating="7.5" audienceRating="7.4" year="2019" tagline="The mission you know. The man you don't." thumb="/library/metadata/156142/thumb/1674651062" art="/library/metadata/156142/art/1674651062" duration="6004957" originallyAvailableAt="2019-07-12" addedAt="1674595604" updatedAt="1674651062" audienceRatingImage="rottentomatoes://image.rating.upright" chapterSource="media" primaryExtraKey="/library/metadata/156143" ratingImage="rottentomatoes://image.rating.ripe">
<Stream id="183925" streamType="1" codec="h264" index="0" bitrate="31318" language="English" languageTag="en" languageCode="eng" bitDepth="8" chromaLocation="left" chromaSubsampling="4:2:0" codedHeight="1088" codedWidth="1920" frameRate="23.976" hasScalingMatrix="0" height="1080" level="41" profile="high" refFrames="4" requiredBandwidths="37733,37143,35867,33956,33514,33132,32584,32584" scanType="progressive" width="1920" displayTitle="1080p (H.264)" extendedDisplayTitle="1080p (H.264)"> </Stream>
<Stream id="183926" streamType="2" selected="1" default="1" codec="dca" index="1" channels="6" bitrate="3369" language="English" languageTag="en" languageCode="eng" audioChannelLayout="5.1(side)" bitDepth="24" profile="ma" requiredBandwidths="3750,3565,3416,3416,3416,3416,3416,3416" samplingRate="48000" title="Surround 5.1" displayTitle="English (DTS-HD MA 5.1)" extendedDisplayTitle="Surround 5.1 (English DTS-HD MA)"> </Stream>
<Stream id="183927" streamType="2" codec="dca" index="2" channels="6" bitrate="1509" language="English" languageTag="en" languageCode="eng" audioChannelLayout="5.1(side)" bitDepth="24" profile="dts" requiredBandwidths="1509,1509,1509,1509,1509,1509,1509,1509" samplingRate="48000" title="Surround 5.1" displayTitle="English (DTS 5.1)" extendedDisplayTitle="Surround 5.1 (English DTS)"> </Stream>
<Stream id="183928" streamType="3" codec="pgs" index="3" bitrate="47" language="English" languageTag="en" languageCode="eng" requiredBandwidths="94,94,94,94,94,94,94,94" displayTitle="English (PGS)" extendedDisplayTitle="English (PGS)"> </Stream>
<Stream id="184201" key="/library/streams/184201" streamType="3" selected="1" codec="srt" language="Southern Kurdish" languageTag="sdh" languageCode="sdh" format="srt" title="Armstrong (2019).eng.sdh" transient="0" displayTitle="Southern Kurdish (SRT External)" extendedDisplayTitle="Armstrong (2019).eng.sdh (Southern Kurdish SRT External)"> </Stream>
</Part>
</Media>
Thanks. Yeah, this is all looking quite ordinary. Nothing stands out as wrong.
Would it be possible to Plex Dance the movie?
Yes, I’ll do that now
The Plex Dance did the trick! ![]()
Just check your database for damage, to be on the safe side:
Or inspect them yourself. Take a look at the Plex Media Server.log file and seek for messages about database corrupt or malformed.
If you find these, you may have to repair your database.
https://support.plex.tv/articles/repair-a-corrupted-database/
Please see the attached logs.
I did not find any corrupt or malformed in the Plex Media Server.log file
