Search alot of back articles, nothing has worked - unable to start Plex - socket issues
Server Version#:1.24.1.4931
Player Version#:n/a
Rebooted my server after a fair length of time running just fine. Error report reports no ports to check, so kinda hard too. Following the log is my port dump, which all seems fine.
This server has multiple network adapters, 1 for main, 2 for HDHomeRuns, and, 3& 4 are a 10G high speed link to my dev box. I even tried procmon.exe to see if I can see a socket error occuring and could not really find one. All firewalls in Windows are ‘off’ as well.
I also tried stop/start "IP Helper’ service, no go.
Sep 18, 2021 13:32:28.108 [2056] INFO - Plex Media Server v1.24.1.4931-1a38e63c6 - Microsoft PC x64 - build: windows-x86 windows - GMT -04:00
Sep 18, 2021 13:32:28.108 [2056] INFO - Windows version: 6.3 (Build 9600), language en-US
Sep 18, 2021 13:32:28.108 [2056] INFO - 32 2500 MHz processor(s): Architecture=0, Level=6, Revision=15876 Processor Identifier=Intel64 Family 6 Model 62 Stepping 4, GenuineIntel
Sep 18, 2021 13:32:28.109 [2056] INFO - Compiler is - MSVC 1924
Sep 18, 2021 13:32:28.136 [0800] INFO - SQLITE3:0x6e5b40fb, 283, recovered 14 frames from WAL file C:\Users\Administrator\AppData\Local\Plex Media Server\Plug-in Support\Databases\com.plexapp.plugins.library.db-wal
Sep 18, 2021 13:32:28.694 [0800] INFO - [CERT/OCSP] Successfully retrieved response from cache.
Sep 18, 2021 13:32:28.694 [0800] ERROR - HttpServer: Error binding acceptor: An attempt was made to access a socket in a way forbidden by its access permissions
Sep 18, 2021 13:32:28.695 [0800] ERROR - Error: Unable to set up server: listen: An attempt was made to access a socket in a way forbidden by its access permissions (struct boost::wrapexcept)
z.txt (209.8 KB)
Shut down any Torrent clients before starting Plex Server. These tend to grab an awful lot of network sockets which can collide with Plex.
The only thing really running in this server is a bunch of VMWare hosts, which won’t interfere, and then plex in the main cpu basically. No torrents etc unless something snuck in!
But it is running SUperDoctor 5 for Super Micro
MegaRAid for my drives
