Hi together,
currently I am trying to establish a secure connection to my PMS on a Synology NAS behind a DS lite connection. I use a portmapper (only http) to connect via DDNS to the server. With a HTTPS-Proxy I can connect via the adress of the HTTPS-Proxy to the server securely, at least the green lock is there
But it doesn’t work via plex.tv/web. I put the adress of the HTTPS-Proxy in the “Custom server access URLs” in the format https://xx.xxx.de/web. Then I get a secure connection but it is remote. So it seems that the URL in the “Custom server access URLs” has no effect. But it works, when I put the Portmapper-URL there → not secure then.
So my question is: Generally, is a secure connection (not remote) via plex.tv/web behind a DS Lite connection possible? If so, how can I establish that?
Thank you and best regards
Manuel
