Select hardware transcoding GPU?
Hi there,
I’m running my PMS in a Debian 10 VM on a vSphere/ESXi hypervisor and I successfully enabled the integrated GPU of the hosts Intel CPU for Plex hardware transcoding.
Sadly I had to disable ESXi’s virtual iGPU to make this work. Plex seem to use the wrong GPU if I don’t disconnect it.
Is there a way to specify what GPU is used by Plex for the transcoding? Would like to keep the ESXi iGPU but still use the Intel one for transcoding.
Best regards
