Regards to all . I am not sure if this is the right place to question and in case I am wrong please accept my apology in advance. My question or request to the creators of the plex server is as follows: Can you add to the option when I set the parameters for movies and specify the language that will be used for the information obtained from TVDB and TMDB, Serbian language? Currently, our group is active in TMDB and TVDB, which work on the database and information about Movies and Series in Serbian. We would be very, very grateful to you for the implementation of the possibility to choose the Serbian language when I type from which language to get information about the film.
There’s a feature suggestion for that – so far it seems this got little attention/support though
Thanks tom80H ,
Vielen Dank
I don’t think that’s a big problem for implementation in plexus. We have organized groups that are now actively engaged in translation into tmdv and tvdb.
We can only hope
