Hejsa
Jeg har har lagt Matador på min PLEX, og slettet den ved en fejl
Nu har jeg oprettet mappen Matador igen, men PLEX finder den ikke,
Nogen der kan hjælpe ?
dane22
September 22, 2019, 1:30pm
2
Prøv at lave en Plex Dance
The purpose of this is to remove all cached metadata and xml data for an item that Plex usually keeps. This helps when you want to “start from scratch” for particular item
move all files for the media item out of the directory your Library is looking at, so Plex will not “see” it anymore
scan the library library (to detect changes)
empty trash
clean bundles (in menu next to server name, when accessed under ‘More’)
double check naming schema and move files back
scan the library
Support articl…
Hej Dane 22
Det hjalp, måtte gøre det 2 gange, da den ikke fandt alle afsnit
