Series 'Anatomy of a Scandal' not pulling in TVdb or TMdb external id and therefore cannot be scrobbled
Server Version#: 1.26.0.5715
Hi All,
Hoping someone can assist or offer some guidance. Plex is not downloading the metadata for the external id of the above series and therefore it keeps failing when trying to scrobble it with Trakt. All my other TV Shows/Movies working perfectly. I have also check Tvdb/Tmdb info if the external ID is available to pull in and can confirm it is.
I am using the new TV agent
Plus one for this, I am getting the same issue. Assume some bad data cached in the plex database
To add some more info: Plex does detect it at the show level, but not at the episode level. This show is only a couple of days old, so I assume it will pull all the info eventually.
Managed to get this Fixed
Click the pencil on the show > Advanced > Change Episode ordering to The Movie Database (Aired)
Great - tried this the other day and now it works. Thanks for pointing out.
