Server Version#: 4.89.1
Hi, all I have a problem I have to upload my tv series correct and for some reason it produces the original titles rather than the named ones. This only happened with this tv series
For example, it should read the name and the episode underneath for that episode, but it shows as DVD_vidio-title Episode 01
sounds like your files contain embedded metadata… some apps write that into the file based on how they first suggest to name the files. You could try removing that or configure Plex to ignore embedded/local metadata in the library’s advanced tab.
Thank you will give that a try
Thank You Tom80H worked great your suggestion, it’s the first time I have come across this in all my uploads
