Series View attitude adjustment
Hello!
Current behaviour under the Series View is that
1. I scroll from the first episode to the actual episode I would like to watch
2. I watch the episode
3. then I have to scroll to the next episode all the way from the first episode again
Would you please change this behaviour? I would prefer if PlexConnect would remember
the last opened position in the episode list and I would scroll from there to the next episode,
not from the first episode all over again.
![post-337312-0-87230500-1427046668.jpg|666x500](upload://cQgow0kObLY8feFiSdX2y8K6r4D.jpg)
Good point. I would love to...
Any idea, how?
This is one of the areas, where some guidance from Apple Inc would help a lot. :-D
Edit: There might be a way... "shelf" comes with...
Edit: There is another option "center"... but it doesn't seem to work as I would expect. Hold on. :-)
Use the "On Deck" feature!!!
From "On Deck", the next episode after the last watched episode will be displayed.
You can press Play directly from On Deck (instead of pressing Select and going to the Pre-Play screen), and once you finish watching the episode, you will be returned back to On Deck and the next episode is ready to watch.
Hm.
"onItemFocused" is another feature - it would call some JS code when highlighting a specific item. Well, that's my current understanding.
"center" option still acts strange...
