Server Version#: latest stable
Player Version#: latest stable
At the outset, I am here as a last resort after a week of wading through everything I can find on the topic on the internet. Nothing has helped: Apologies in advance if I sound like I’ve lost the plot.
YourServer is currently unavailable
Verify you have a network connection and that the server is online, or see our troubleshooting tips for further assistance.
PMS had been working reasonably reliably for some months. A week ago this nonsense started. PMS content is only available on localhost. Client access from other IP addresses on the LAN fails.
I emphasise nothing I am aware of has changed locally. The LAN seems to be well behaved, the internet connection connection is fine, I have disabled the VPN, I have logged in, logged out, logged in, purged, reinstalled etc etc. No joy.
I have been through the “troubleshooting” guide. Although things check out OK the issue remains.
PMS is scanning media files on the LAN (NAS) no problem.
Today I did a clean install of linux and PMS, but the problem remains: " is currently unavailable Verify you have a network connection and that the server is online, or see our troubleshooting tips for further assistance."
My debug or my friend’s sever debug? The op is having issues with their server, it is happening to me when I try to connect to my friends. If you need him, I can ask him for them.
I will ask him for the logs, also I noticed when looking at a movie in the library or playlist or adding it to watch, it will reload to the top of the list instead of going back to the movie I was on, I posted a forum post about it. Could his logs help with that or is that more on my end?
As a process of elimination I’d try the method of removing your device from the authorised device list (see my post above).
Then try to re-establish the connection. You’d probably want to to do this in consultation with the PMS owner. If it works, good. If it doesn’t, suspect a network or permission issue.
Mind you, I have never been able to get remote access to work anyway. I tried getting help here once but only managed to get flamed for being too stupid to use plex.
We tired moving the authorized and re-authoring the device, but no go. Still randomly stops showing images, then says no content and then unavailable, my friend when he tries to access his own server remotely also gives him that error. He said he would get logs and send them to me and I will upload them here.
@ChuckPa did the logs reveal anything? My buddy is having the same error, that the connection is not secure, or it is unable to verify when he tries via the web browser at his house.
Yes, that is correct. They are both Shield servers, but Cthulhu is mine and Zocalo is my buddies. He is also going to check some settings, I will uninstall and reinstall the player on my end.
I don’t know if that is setup to be forwarded or not correctly, This was working fine for years and suddenly just started having problems in the last month. What do I need to check? Cthulhu server works fine, it is the Zocalo one we are having trouble accessing. What should my friend check don’t he WAN settings? @ChuckPa
