Server Version#: 1.105.2.269-12a32491
For the second time in the last few months, my server suddenly became unavailable, and then a couple days later, vanished completely.
The last time I tried all common troubleshooting, but nothing seemed to work although the issue did resolve itself at some point and the server was back and working normally.
This time, I haven’t done anything other than making sure it was up to date thinking/hoping it would resolve itself again. It hasn’t, and now it’s been down much longer this time than last.
Any ideas how to fix it, and what’s causing this to happen?
What troubleshooting steps were that in particular?
Is this about a native PMS on Windows installation or are you running PMS in a container?
Is your server data directory on the machine itself or stored elsewhere?
Server logs might give a hint on what’s been going wrong (unless the “becoming unavailable” is too long in the past).
An important detail will be:
Is the server only disappearing from that particular client or is it vanished from all apps (e.g. including the web app if accessing it from the same machine hosting the server via http://127.0.0.1:32400/web).
Are you sure there’s a PMS icon in the system tray?
Unless you’ve configured your server to store its data directory somewhere else (which will include a different location for logs), that’s the last log and your server last ran on Dec 11 at approx. 6:45pm
If I open the Plex app and sign in on my laptop, the PMS icon is shown in the sys tray, but I can’t get it to show on the host PC. Is that the issue here? I’ve uninstalled and reinstalled it on the host PC, but nothing changed.
Would you mind sharing what is showing in your task manager?
If PMS isn’t showing in the system tray, the server itself isn’t running – at least not properly.
Out of curiosity…
when you write the icon is showing in the system tray of your laptop but it’s not showing on the “host PC” – I assume that’s not the same machines?
Yeah the actual host PC is a desktop/server I built to host the files. It’s worked flawlessly for like 6 years with no issues until a few months ago. I can sign in to my account with the app on my laptop. I’m also signed in on several smart tvs. Of course my server isn’t showing up on any of them.
