My server is up and running smoothly. When I go to log into Plexamp, my serve doesn’t appear at all. I’ve uninstalled the app and reinstalled it, empties the cache and data and still I cannot select my server once I log in. Anyone experience this or know how to fix it?
Server Version#: Version 1.32.0.6918 (NAS)
Player Version#: Plexamp 4.6.3 (Android)
Does your server already have a “Music”-type library?
I was just able to get it to work by switching to my mobile network. For some reason it picked up my server there. Guess my WiFi had a brain fart. Thank you!
Nevermind. Now I can’t get it to load on WiFi, but works fine on 4G. Any guesses? And yes, of course I have a Music type library.
27689933087039.zip (45.6 KB)
Logs here if anyone can help!
Posted them just before you posted
Can you use your server with other client types in the local network?
Is the connection type of these shown as “local” on the Dashboard?
Oh ■■■■… now I can’t access Plex or Plex Dash via the apps on my phone either. Only on 4G. Otherwise other devices can use it without issue. Any idea why?
DNS rebinding protection.
Thanks. I guess I’ll give this a try. What’s odd is that I was able to use both without issue for a full day before this happened.
Did you change something lately?
For instance, disabling Relay Connections in Plex, or separating your WiFi from your wired network? Added a new firewall/internet filter, like Pi-Hole etc.?
I got a new Netgear Orbi router a week ago, but we’ve been able to use it just fine until today. Haven’t changed anything as far as wired/wireless setups go, or even the configurations on my WiFi itself. Same SSID/pass.
I’m an ■■■■■■■■ I forgot I was getting a lot of DOS attacks and set my QNAP to deny anyone who failed login once. I failed the login once on my phone, which blocked all of Plex. Removed myself from my blocklist and it’s working fine. TY for your help!
