Server Version#: 1.43.3.10896
I’m running Plexamp on my android device. It is unable to find my music library (which does exist). I believe the issue is because I removed a server and created a new one. I think Plexamp is continually looking for the old server that doesn’t exist. Is there any way around this? I can’t proceed to Plexamp settings because I get blocked by the Select a Library screen.
I mean that when I open plexamp, I am instantly asked to connect to a library. Because I’m unable to connect to my music library, I get stuck on this screen. There are no menu options or buttons to click. I can’t get to a settings page or account menu. I’m literally stuck there.
I can see my other plex libraries within the plex app on my android (remotely and in-network). I am port forwarding my plex server and remote connection is working (I can actually see all my libraries including music in my Plex app on Roku).
I did not migrate my original setup/server. I removed it and created a new one.
to me it seems like when you try to connect, it doesn’t loop through all of your servers. it just tries to connect to the first one it finds (and then gets stuck, cause in this case that server no longer exists) and errors out. seems like there is no try/catch block in the code, where it can catch a connection error and proceed to the next server in the list.
i tried long pressing the sign in button in my plexamp app (android), but there was no action afterward. i had to short press it to actually login.
i also tried this on my plex app (android). same thing.
let me know if i did this wrong or you meant to long press somewhere else or on a different device. thanks!
Any update on this? I’m also having problems with PlexAmp not finding my servers with the Android app.
I changed my Plex password this morning (accidently left myself signed in at a rental, so… Time to change that). Signed in on the server, AndroidTV, browser, and Android app fine. PlexAmp and Plex Dash on my Android phone go to the “Select a Library” screen, search, and then end with “no libraries found.” Both PlexAmp and Plex Dash worked fine on this phone this morning, before changing my password. I tested them on my iPad, and they both can find my libraries on there. Tried with a second Android device, and had the same issue where it couldn’t find my libraries there. Have tried uninstalling and reinstalling the Android app without success.
Attempted to get you a log, but long pressing the log in button returns a “something went wrong” error.
