Server rarely works, it's infuriating
Server Version#: 1.19.4.2935
Player Version#: 8.1.2.18135 (although any player I try to access)
Pulling my hair out with this. I have been using Plex Pass for 3-4 years. I have the server set up on a Mac (2010). Internet speeds upload and download are absolutely fine (50mb/s & 10mb/s). All was fine until around 8 months ago when Plex became unreliable and unstable, constantly reporting…
‘Oops something went wrong. Please trying again in a few minutes’
…when accessing via web browser on the actual host of the media library (Version 4.30.2).
When connecting via any player, even when successfully accessed on host Mac via web-browser, everything is empty. After much messing about I finally get the items to show (I’m using Amazon, LG Smart TV, PS4, iOS players) if I get something to play (even a tiny file in SD) there is loads of buffering, if I interrogate the library in any way it crashes, if I watch a film there is buffering, it crashes after the film and needs to be re-booted. I’ve checked settings, uninstalled, reinstalled, ensured nothing else is running on the Mac (which works perfectly) and checked internet speeds, used WiFi, Wired. Honestly tried everything I know of, but it remains horribly unstable.
Any ideas?
All help appreciated.
DataFunkz,
First, there are a number of basic steps which I assume you have already tried (optimizing the database and cleaning bundles for example).
  • When you say you have done an uninstall / reinstall are you referring to the MacOS or just the Plex server program? I am guessing you are only doing an uninstall / reinstall of the Plex server program. Perhaps there is some remnant of the previous installation which is causing the problem to persist. Starting from scratch with a clean system install might resolve the issue. This is the technique I have used on the rare occasion a glitch has manifested itself. This includes allowing the clean install to re-acquire all meta data rather than trying to restore from a backup. I also have a spare server ready to go - Just in case!
  • Is the computer used for anything else, or just Plex? Any chance you have picked up a virus?
  • Have you monitored the server’s activity when trying to watch media? Activity Monitor and / or the Plex Dashboard offer a window into system resource utilization.
  • Another thought… Do a fresh install and only add a single media file to your library… Just one movie for example. How does it work?
  • Do you have a second computer you can use as a test bed?
  • You didn’t really say much about the computer itself… 2010 Macintosh… Mini/Pro/iMac/Book? CPU (C2D/i3/i5/i7/Xeon)? OS? RAM? Drive(s)? Perhaps there was a Plex update 8 months ago which is causing issues with your configuration. Are the media files stored on an external drive / array? I am running a 2009 XServe, but recently upgraded it to 10.11.6 as 10.9.5 was becoming a bit troublesome. Have you run any OS or system checks? I am a fan of Onyx as a basic system check and cleaning utility.
Best I can come up with until I have more coffee.
Cheers, I’ll have a work through those potential solutions…
It’s an iMac 2010, 3.06 GHz i3 16GB RAM, Media all on ext HDD’s, not used for anything else.
recently had similar problem on my server, can you upload the logs from PMS?
Certainly. I’ve downloaded the logs from PMS, do you want all of them?
yes in zip file
and can you give me screenshots of your Remote Access page in settings, Network in settings and Library in settings and Schedule in settings and ofc Transcoder page in settings
Plex Media Server Logs_2020-06-17_20-57-35.zip (5.1 MB)
Thanks for your help! Please see uploaded screenshots attached..
Library Settings 2|690x394
I see in your logs that you still have a bunch of plugins installed. Since these don’t work anymore, I would recommend removing them.
Off the top of my head… I would disable IPv6 - Unless you actually need / use it.
I don’t think I ever used the plugs in, added them, looked at them and left them. Will delete forwith.
Will do!
Thanks!
“Transcorder default throttle buffer” set to 60
“Transcorder temporary directory” make folder with the right permissions and put in its location in the box.
“Custom certificate domain” https://84.64.247.47:26585
“Custom server access URLS” enter: https://84.64.247.47:26585/
“Terminate sessions paused for longer than” raise to atleast 10.
“Run a partial scan when changes are detected” turn off.
“Scan my library automatically” turn off, scheduled task does this daily.
“Empty trash automatically after every scan” turn off this is done every 3 days by maintenance.
“Maximum number of on deck items which will appear” lower to 30.
“Enable server support for IPv6” turn it off.
“Secure Connections” to Preferred
and last turn off the limit on internet in remote access, leave it empty.
and turn Secure Connections to “Preferred”
and turn of verbose logging in the General tab in settings
All done! Thanks!!
I’ll give it a go and see how it behaves now.
It’s already working 1000% better than it has for the last few months!
Thank you all for your input and advice, much appreciated!
IPv6… The scourge of civilization!
