Server Version#: 1.25.2.5319-c43dc0277
Player Version#: Chrome, Firefox and Edge on Win 10
Hi all,
Running Plex, installed from the repository, on Ubuntu 20.04.3 LTS x64.
This afternoon I updated a bunch of stuff and noticed I could no longer connect to my Plex server from any of my devices, or the Web Player, on the local network. I can connect to the locally hosted (port 32400) instance of the Web Player, and so I know Plex is running, but none of the server configuration options appear. I’ve subsequently purged the plexmediaserver package, deleted all the remaining configuration data I can find, and when accessing the local instance I don’t get the Setup Wizard, just the Web Player with no server settings or any of my media.
Things I’ve done:
Ensured the server and the client machine are on the same, wired network
Disconnected all VPN connections
Disabled DNS rebind protection on my router
Flushed the DNS resolver cache on Windows
Signed out and back in to all instances of the Web Player
Tried it in Chrome, Firefox and Edge
Created a new user account via the locally hosted instance of the Web Player
Done sudo apt purge plexmediaserver, also removed everything under /var/lib/plexmediaserver, rebooted, and then added the latest plexmediaserver package as described here
torn out some hair
done a lot of googling
had a beer
remained stuck without access to server settings or the setup wizard
posted here
Please help! My kids are going to be sad that they can’t watch movies!
If the URL you use to connect to the hostname is a FQDN – it’s retreated as non-local because Plex doesn’t know the FQDN is local until AFTER you add your cert to Plex AFTER claiming.
You must have IPv4 enabled in the host’s stack. 127.0.0.1 (the loopback) is required for Plex to work.
It’s weird way of doing things but not a bug. All this stems from the clients working in WiFi cafes and making sure the server isn’t compromised. I don’t understand it and therefore don’t understand why the strictness.
