I’m not sure if this has only happened tonight but when I click on SERVER I get the message “Server settings are unavailable”.
Im using Synology, Plex version 1.10.0.4523
Anynone has any idea how can be fixed?
v
v
You are somehow locked out of your server.
Plex sharePreferences.xml
http://ip.addr.of.syno:32400/web again (same as with first-time setup)Thanks it worked fine!
On Sun, Dec 17, 2017 at 8:23 PM, ChuckPA forums+d299887-s6025034@plex.tv
wrote:
Plex Forums https://forums.plex.tv/
ChuckPA answered your question: Server settings are unavailableYou are somehow locked out of your server.
- Control Panel - Shared Folders - Edit the Plex share
- Give your username R/W permission
- Stop PMS in Package Center
- Open File Station
- Plex share → Library → Application Support - Plex Media Server
- Delete Preferences.xml
- Start PMS
- Open http://ip.addr.of.syno:32400/web again (same as with first-time
setup)- Step through the first-time setup wizard as you previously did except
Do Not create any new Library sections. Skip that part- Arrive at the Dashboard
- Settings - Server
- Check the basic settings and set them again. Some will have been lost
in the soft-reset.–
Reply to this email directly or follow the link below to check it out:
https://forums.plex.tv/discussion/comment/1575905#Comment_1575905Note: Your signature will be included when replying directly by email
unless you remove it first. Attachments will not be included when replying.Check it out: https://forums.plex.tv/discussion/comment/1575905#
Comment_1575905
I have been annoyed at the “Server settings unavailable” for a while. The above method worked a treat, thanks.
