Server Settings
Server Version#:1.39.1.2763-300bb607
Player Version#:N/A
For some unknown reason I can no longer my Plex server settings. Not sure what happened but I noticed it a few days ago. I have attached a screen shot of the error message. It happens irregardless of any of the server settings I choose. All the other settings work just fine; i.e., general, quality, player and downloads. I am sure it is probably something simple but for the life of me I can’t figure what. Please help
It seems you missed that screenshot you intended to add to your post.
Similar issue here. Only been using for less than a week and really started to find the program useful and now I cannot access.
Getting error message:
app.plex.tv is unable to connect to “BEEFHUB” securely
Its “Secure connections” setting may be set to disabled, or you may need to adjust some settings on your network. You can learn more about secure connections here.
I had changed no settings but now I cannot connect to my server.
It seems I can open though application but not through web browser.
Same problem I’m having, just upgraded to version 4.66.1. I have been using PLEX for several years and have not seen this error until this latest upgrade.
I’ve checked all my settings, they are correct :
Remote Access - Green Tic
Network: Preferred
My router setup is unchanged and I can access it through any app, TV, Apple and Android.
I’ve read about deleting the server cert in past forums, I was only able to locate 1 certificate on my Mac, but it did not match the v2 that was listed in the forum I was reading?
Same here. Plex on Apple TV and Nvidia Shield will not connect to computer using 4.66.1
Server Version 1.25.1.5286
It seems to be working again.
