Setting Plex bandwidth at the server side
I would like to know if it is possible to set the bitrate higher than 20mbps on the server side for remote streaming.
Thanks for the help in advance.
There’s 2 hidden/advanced settings for this in Settings > Server > Remote Access:
  1. Internet upload speed sets the max. bandwidth available to all streams
  2. Limit remote stream bitrate sets the max. bandwidth per stream
As for the dropdown values in #2 there’s one option above 20Mbps (1080p)… that’s Original (No limit) – however there’s no setting in-between.
I wish there was some way to adjust between 20 and Original. I use Emby as well and that option is available there.
