Setting up Hauppauge HVR-955Q
Hello, I just upgraded to Plex Plass Premium after seeing the 955Q is now supported. After updating to 1.7.2.3878 I can still not figure out how to get plex to detect my tuner.
I go to the DVR tab under settings, then click “Setup Plex DVR” and it just sits at “Looking for compatible devices on your network.”
What am I suppose to see? And how do I get this working?
Also I am running Ubuntu 16.04 LTS
Have you looked at http://www.hauppauge.com/site/support/linux.html ? Check out the 2nd tab “Plex and Hauppauge TV tuners”. This should allow you turner to be recognized after completing these steps. What Linux kernel are you running?
Side note, my Linux server does see this turner but cant find any channels what so ever (https://forums.plex.tv/discussion/274173/xb1-tuner-wintv-hvr-955q-cant-find-channels#latest) If you run into any issue please review this thread and see if you get any of the errors I do. GOOD LUCK!!! I’m still looking into my issue to date!
FYI, I did get my setup to finally work! I found the issue to be with VMware ESXi. Even though I added the device to the server and PLEX saw the device, it would never pick up any channels. I completely wiped the server clean, installed Ubuntu 16.04.1 directly to the server (no virtualization) and followed the directions in the link I posted above and all works fine now!
