Setting up live tv/dvr managing channels problem
when I setup my Hdhomerun extended for live tv/dvr but I encounter a problem. there are two channels that are found but I am unable to select the correct guide data since it does appear in the drop down list. for example I know 10.3 KMEB-S2 is PBS Kids local but there is no guide data for that channel leaving it blank unselects the channel. is there a way to add in the guide data so that it will show up?
Also on a side note Hdhomerun found a channel 4.3 KITV-D3 but I can not find out what that is and there is also no guide data.
Thank you.
Kurt
I took a screen shot showing the problem.
Regards
Kurt
