Share naming on Synology NAS
Server Version#: the one for DSm7
Player Version#: none set up yet
Blockquote
We urge you to NEVER USE the predefined video, music, or photo shares that Synology created.
Blockquote
OK, then. Understood. But, can one delete them then use the same names for shares after deleting theirs, or do they need a different name?
I’m very new at this; I am starting over after fighting a losing battle with a WD NAS. Thanks, gang.
I guess that recommendation is to avoid collisions with other apps using those same shares and potentially messing things up (e.g. changing file names, reorganizing files…). Personally I’ve been using the standard folders for quite some time (years) without issue. That being said I’ve also never allowed any other apps to work with those shares… so no risk of collisions.
As it is, Synology didn’t create any of its own shares. Now, a new problem. I installed Plex, not allowing it to run after installation. When I created a Share (called DMMedia), I found only myself, guest, and Admin. I had to go back out and add in Plex, which (whom?) I named “plex” (all lower-case like shown in the step by step installation doc for Synology. I went into File Station and created folders in my DMMedia shared folder. Mvvies, Movies, Silent, Soundies, Music, etc.
I then started Plex Server, and wanted to start adding libraries. None of the folders like Soundies etc show up.
What am I doing wrong? Thanks in advance…
After running the Plex Media Server on your Synology NAS with DSM 7, you should be able to set/pick permissions for its standard user (PlexMediaServer).
Got it! Thanks very much. I likely will have more questions, but will try to suss things out for myself in the meanwhile.
