So my family and I are planning to setup servers for dumping photos and videos of all mobiles/cameras from vacations and functions to make it visible to all the members willing to see. I love watching them on my tv rather than on a web based display. In my home I’ve a FreeNAS box running and I’m using rasplex connected to my tv which is able to fulfil my needs. My libraries are shared with my family memebers. So my question is in 3 parts
Suppose I share a folder with my family members X and Y can they also watch the same content remotely with their sign in through Rasplex?
Now for eg X also makes a plex server and gives access to Y and me will I also be able to see X’s content without any changes?
Suppose X and I share the same pics from our (different) servers and the name of the folder is also same (eg “Spain”) what will Y see on his Rasplex? Will I see duplicate files?
Thanks for the quick replies. This is awesome news. I guess then I can just distribute Rasplex to every one and get done with it.
Just 1 last doubt. Say X and I both create a library called Spain. How will Y or I know the difference between the 2 Spain libraries?
It will be indicated on the screen by the user interface which server the library originates from. How depends on the skin you are going to use and in some cases on some settings.
Each server will have its own name even if the library has the same name and they are both of the same Plex Pass family group. So if you use Rasplex the name of the server will be shown bellow the library name. If you use most other plex clients, you first need to choose the server to watch.
If the user that is sharing is outside of the plex pass family, I think it will appear under a shared folder if I remember correctly
