Shield PMS external HDD failed
Hi All,
The dreaded moment has arrived, unfortunately earlier than expected (doesn’t it always…). My 3TB external USB drive for my Shield TV has failed and (according to a specialist) cannot be saved or any data extracted. And no, I didn’t have a backup (just too costly). To make things worse, I had the server data saved to the external drive… So my questions are:
PMS has stopped and cannot be restarted. I guess I need to delete all app data and cache to get it working again, or is there any other way?
When I go into Plex, I can still see the thumbnails of all my movies and series. Is there any way I can extract a list so at least I know what I had downloaded? I went into all folders on the internal drive related to PMS but couldn’t find any files related to database, is there anything within the Plex App?
Is there a way to save my PMS settings (eg things like shared user accounts, plug-ins, etc) or do I need to start over from scratch?
I have a very old server backup from before I moved the PMS data to the external drive. This could at least help with the settings, but not with the library. But from what I understand there is no restore process.
Any help is greatly appreciated
Unsure if it’ll work on a Shield, but try this:
As an alternative, there’s also this:
Hi, thank you but my database backup also was on the failed drive. All the PMS data is on the external drive. I will try this with the old backup, at least I will have the movies up to 2 years ago.
If you still can see the posters, then skip the part about restoring database
I can’t figure out how to use this ExportTool. It needs to be installed in the Plug-in folder, but I have no plugin folder as ALL my PMS data is on the failed HDD. Somehow I’m still seeing the thumbnails though. All I want is to extract this information somehow.
Not a shield user, so as said, unsure here, but:
And when said, it might be an alternative to download the database, and then open the table named media_parts with something like: Downloads - DB Browser for SQLite
