Shield Pro 2017 TrueHD audio dropouts
I’m having trouble with audio dropouts in BR remuxes with TrueHD audio. My setup is a 2017 Shield Pro as a Plex client, Ubuntu 20.04 with PMS via docker. The Shield has an HDMI 2.1 cable attached to a Vizio P85QX-H1, and then eARC (HDMI 2.1) to a Vizio M512A-H6 soundbar (firmware v2.0.0.4). The Plex client is set up with audio passthrough via HDMI.
It sounds similar to this thread (96khz/192khz Audio Dropouts) but the files I’m having issues with are not 96/192khz.
I just got the soundbar so I haven’t tested too much, but both of these have the same issue. Audio will be playing fine, and then drop out for a second before coming back. It appears to happen at random. Sometimes several times in a row, or once after 20 minutes of playing fine. The logs don’t yield any hints or issues.
Ready Player One
* Codec HEVC
* Bitrate 66799 kbps
* Language English
* Language Tag en
* Bit Depth 10
* Chroma Location topleft
* Chroma Subsampling 4:2:0
* Coded Height 2160
* Coded Width 3840
* Color Primaries bt2020
* Color Range tv
* Color Space bt2020nc
* Color Trc smpte2084
* Frame Rate 23.976 fps
* Height 2160
* Level 5.1
* Profile main 10
* Ref Frames 1
* Title MPEG-H HEVC Video / 62963 kbps / 2160p / 23.976 fps / 16:9 / Main 10 Profile 5.1 High / 4:2:0 / 10 bits / HDR / BT.2020
* Width 3840
* Display Title 4K HDR10 (HEVC Main 10)
* Extended Display Title MPEG-H HEVC Video / 62963 kbps / 2160p / 23.976 fps / 16:9 / Main 10 Profile 5.1 High / 4:2:0 / 10 bits / HDR / BT.2020
* Codec TRUEHD
* Channels 8
* Language English
* Language Tag en
* Audio Channel Layout 7.1
* Bit Depth 24
* Sampling Rate 48000 Hz
* Title Dolby Atmos/TrueHD Audio / 7.1-Atmos / 48 kHz / 3666 kbps / 16-bit
* Display Title English (TRUEHD 7.1)
* Extended Display Title Dolby Atmos/TrueHD Audio / 7.1-Atmos / 48 kHz / 3666 kbps / 16-bit (English)
John Wick Chapter 3
* Codec HEVC
* Bitrate 70210 kbps
* Language English
* Language Tag en
* Bit Depth 10
* Coded Height 2160
* Coded Width 3840
* Color Range tv
* Height 2160
* Level 5.1
* Profile main 10
* Ref Frames 1
* Title English
* Width 3840
* Extended Display Title English (4K HDR10 HEVC Main 10)
* Codec TRUEHD
* Channels 8
* Language English
* Language Tag en
* Bit Depth 24
* Title English
* Extended Display Title English (TRUEHD 7.1)
I don’t experience these issues while playing the same files in Emby.
Server Version#: 1.28.1.6041
Player Version#: 9.6.2.34353
Would it be possible for you to enable logging in the player app
then recreate the dropout .
After recreating, stop playback and download the player logs from the shield.
Attach those logs here please.
Also please advise which version of Shield Experience is installed
I switched up the order to Shield > soundbar > TV instead of routing through the TV with eARC and was able to play about 45 min without interruption. No idea why I was only experiencing the issue with Plex, but I’ll comment again if I experience issues with this new configuration.
