Shin Chan (2006) Poster and Metadata Incorrect
The “Plex Series” agent has incorrect metadata for Shin Chan (Funimation, 2006).
First off, the poster is incorrect. The poster shown is for “Crayon Shinchan”, which is the name of the original Japanese show, but is not correct when referring to the English version which is simply called “Shin Chan”.
Next, the original Japanese cast is listed for the show, rather than the actual English voice actors in the English dub.
I tried to fix the match using “tvdb-437356” as the show search term, but that only confirmed that it had already matched correctly and that the metadata was simply wrong.
I tried prioritizing The TV DB metadata higher than all others in the Agents configuration settings, but the correct poster and cast from the TV DB still do not appear for the show.
For now, I am forced to use the legacy TV DB agent.
Server Version#: Synology (Docker) 1.40.0.7998
Player Version#: Plex Web 4.123.2
Thanks for report.
Just wanted to confirm this is the entry at TVDB you are tyring to match it to Shin Chan (2006) - TheTVDB.com
Yes, that’s the one!
This appears to be working now. ( though you need to select TVDB (aired or absolute) for the episode ordering for that show since TMDB does not seem to have the 2006 english show at all.
