Should be able to order DVR devices
I have two different DVR devices:
1- HDHomeRun CONNECT
2- HDHomeRun EXTEND
The EXTEND is better for me, since it automatically in hardware compress before sending it via my wifi to the Plex server. However, I’m not able to get it used first before the CONNECT. I try removing and adding in some order, but CONNECT always end-up to show first in the UI, and also get used first.
Ideally, I should be able to ‘drag’ them in the UI in the order I want.
If you select the recorder in different ways like to avoid conflict (let say some recorder doesn’t have channel X) and we are recording simultaneously 4 channels, I would like to a link to the logic and would like we have an option to give priority to ‘compressed’ channel like EXTEND provide if not other priority are in conflict.
Only way to edit the order of tuners is to manually edit the database. See forum thread:
Tuner Priority
