Simultaneously Recording Two Channels xteve
I noticed that I’d two programs are scheduled to record (ota using HDHR) one will not record. I am going to try again and set one recording to begin 2 minutes prior to the second. This may be something that may need to be looked into by developers as a setting or some sort of default. Maybe 20-30 second delays when same time recordings are scheduled?
That should work unless you only have 1 tuner. I don’t use Xsteve, but it may be a limitation of how it is mimicking a tuner.
In my case it makes no difference starting recordings one by one. I use always +/-8min.
In some cases single recodings fail to start, and in some cases 4 recordings starting at the same time works like a charm… - in rare cases nothing works or you have to restart the recording 2-3 times manually…
For me it’s more a timing/timeout problem, so if my Synology DS920+ is on load, recording works more reliable.
