Skip movie trailer on TV shows and or some folder
Server Version#: Docker 1.41.8.9834-071366d65
Docker compose version: 2.20.1
Player Version#: Windows:latest
Good afternoon, in my plex library i also have some old video tapes from my vaction converted to mp4. Files, plex degine them as movies. I would like to know how i can change it to TV show catagory instead. Or else is there a way to disable trailers for TV shows, anytime my parents waching an episode there getting the local trailers file seen each time. Can you tell me whhere i can ask this to get a prober answer? Thank you alot Support!
You can disable trailers for certain libraries in each movie library’s advanced options (… > Manage Library > Edit… → Advanced > Enable Cinema Trailers).
Another option might be to create the library as „Other Video“ library (new library, pointing to the same folder).
If you want to present your library as a tv series library, make sure to reorganize your files to match the naming schema for tv shows; then create a new tv show library and configure it to use the personal media agent.
https://support.plex.tv/articles/categories/your-media/naming-and-organizing-personal-media/
Disables the Enable Cinametic Trailers here and it seems to work for now, thanks alot for the quick response!!!
