Smart Shuffle - Does not work on Smart Playlists or Library with Filters turned on
An error occured loading items to play…
Please be more verbose. What doesn’t work? Where? Under which circumstances?
Sorry if I go to a Smart Playlist (Created from Filters) or a Music Library with filters applied… Then hit the shuffle button. I get the error above…
Which client type?
Which software version of the client?
Which software version of the server?
Tested some more…
Plex Server:
Version 1.19.1.2589
Plex Clients tested:
Browser
PMP
Android
All clients throw an error when the Smart Playlist or a Library with filters on has higher then 1000 tracks (I think this is the cutoff)
I just shuffled a smart playlist with over 37.000 tracks. So that’s not a general bug.
What platform does your server run on?
How much RAM does it have?
Windows Server 2019
8GB
Here is the error in the logs that immediately follows:
Looks like I have a DB problem with a track?
This is the error I get in a browser:
The smaller lists work (no errors and Play) but I assume the larger playlists I created I assume have the problem track/tracks?
That’s a good working theory. I’d lookout for files and folders with special characters in them, like é à â etc.
Are the media files stored directly in the server machine or are they mounted from network shares?
All files are mounted on SMB storage. I’m sure there are tracks with special characters (Not characters that are excluded by file/folder naming requirements)
There are sometimes codepage issues when file server and plex server are running on different OS platforms. But these kinds occured recently only from Linux (e.g. a NAS device) to Mac…
Plex Server and Storage Server are both Windows Server 2019.
Say, did you move the Plex data folder to the network share as well?
No Plex data folder is local to Plex Server (in APPDATA).
