I updated the Plex Media Server to 1.3.2.3112 and now anyone with an Android device is unable to play media.
The message displayed is "Playback has stopped because the connection to the Plex Media Server has been lost. Please ensure that the server is available and retry.
Followup. A number of users thought, by turning on Jumbo Frames, they would get more throughput. This is counterproductive and PMS will be unable to maintain a stable connection unless all devices have jumbo frames enabled. The primary problem with this is a) not all devices support jumbo frames and b) jumbo frames are entirely pointless and result in overwhelming fragmentation when using cellular data which uses a 53 byte packet (48 byte payload + 5 byte header).
If you have them enabled, please turn them off before attempting to diagnose further.
I have noticed that some media does play, it looks like anything that can use Direct Play works ok on all devices, but anything that needs transcoding does not work on Android or Windows.
I will need your logfiles to see why you are having transcoding difficulties (settings - server - help - download logs). Attach the zipfile with your next post
To add in here, I’ve noticed that my FireTV (v2) and FireTV Stick (v2) both lost their ability to connect to Plex after upgrading Plex to Version 1.3.2.3112
Disabling the secure connections only on the client side for each device was a workaround for the issue.
