[Solved] Moved/ splitted media server - connection issues afterwards
Server Version#: 1.14.1.5488
Hi Plex-aficionados,
I moved (cloned) my Plex server to another PC using this way…
https://support.plex.tv/articles/201370363-move-an-install-to-another-system/
After that I moved a part of the media content, which I wanted on the other instance and cleaned up the library. So far it works like a charm.
Problem is, both servers are in the same local network/ ip-range and all my players (PC-browser, Android, Fire-TV, LG semi-proprietary player) seems to have an issue conecting/ switching between the servers. It’s more like a guessing-game which server answers faster, as long as I’m not selecting the server I want by the ip.
I assume the server has some sort of internal ID and it appears to the client/ player two times. Any suggestions how I can solve this?
Thanks in advance.
eos
If you “cloned” it, both machines now are using the same machineID.
You need to make them unique again.
see I want to backup my Genre tags from one server and restore them onto a new server
Worked!
Many thanks!
