Some Bugs on Plex for Xbox One
Hi guys,
I started using the Plex app for Xbox One around the same time it was released. Since then, I've run into a number of bugs that I encounter frequently, if not all the time. Here they are:
1. When adding or changing subtitle language, I understand that PMS creates a brand new transcode session for it. However, for some reason the previous transcode sessions are left running. I could be watching only one thing on one device, but when I check the status of the server, I see sometimes 3 or more sessions, and these are left over way longer than they're supposed to. They eventually go away, but hang around much much longer than before. This was not an issue before the Xbox One app and version 0.9.10.3 of PMS, where old sessions would be stopped much earlier or instantly.
2. I'm also seeing double back buttons, I've attached a picture to this post.
3. Finally, another issue I'm encountering is after watching any piece of content, the last 2-3 seconds will repeat itself before actually ending.
Has anyone else encountered these issues? This is my first post here, I apologize if this has been covered but wanted to highlight them just in case they haven't. They're not deal breaking problems by any means, but I'm sure we'd all prefer for them not to exist :)
Full confirmation for every single point on my side. ;)
Thanks for the detailed reports. We'll raise those internally and look into them. Hope they're not impacting the experience too much!
I'm seeing a repeat of the last few seconds and also I'm getting a pause when starting shows or films after the first five seconds or so, then after a pause of about 10-15 seconds they resume and play fine. It would be cool to get them fixed but ultimately for the time being the excitement of having the app is making these small things seem pretty insignificant.
Found another bug, this one a little more significant. I can't play stacked TV shows or multi-part movies. When the first part is supposed to end, it'll show the first frame of the next part then immediately start playing the last 20 seconds of the first part all over again before ending.
Hope you guys can fix that one in the next update!
The double back button issue appears when using Kinect commands also.
Please solve this problem. I have many more parts in movies and I made a subscription plex to see on my xbox !!!
