Some libraries aren't working
Server Version#: 1.30.1.6562-7000
Hi, all. I am using Plex Media Server on my Synology, and I have noticed that some folders do not work – specifically, I have a library called “Other shows” that is a “Other videos” type library, and it has valid folders assigned to it, and files inside the folders, but the library just doesn’t work.
When I say “the library just doesn’t work,” specifically what I mean is: When I am viewing the library in any Plex client (macOS, Apple TV, Roku, iPhone, doesn’t matter) the library shows up as a “?!” symobol next to it (a ? in a gray circle, next to a ! in a yellow circle).
This is not a recent issue: over the course of a year or so, I have tried various things to get these libraries working, but they never do.
The libraries did used to work, once upon a time. I do not know what changed to make them not work.
I would really like to get these folders working; anybody have any ideas on what I’m doing wrong? Thanks.
Can you show me?
Screenshot and/or your server logs ZIP file after you try to access it?
Here’s the library in the listing. I will get the logs soon.
Screen Shot 2023-03-05 at 20.57.03
There are no logs to gather – it is not possible to browse these libraries.
I looked at what Plex.tv knows of your server.
It sees 14 Library sections. Is this corect?
Yes, 14. I just confirmed on my server.
Now that I know what i’m looking at, may I have the server DEBUG log files ZIP after you try to access some of that ?
There’s no way to access it – clicking on the library does nothing. It’s simply not available.
You do have sufficient access to the machine for Syno desktop and Package Manager ?
Hi Chuck. Yes, it is my Synology. I can SSH into it if that helps.
I’m thinking of how to get the logs (manually captured)
  1. SSH into it
  2. sudo bash (jump to root)
  3. synopkg stop PlexMediaServer
  4. cd "/var/packages/PlexMediaServer/shares/PlexMediaServer/AppData/Plex Media Server"
  5. tar cf SynoLogs.tar.gz ./Logs
  6. Now you can scp them back to you or do what you want from Filestation to download it and attach here.
