Server Version#: v1.16.3.1402-22929c8a2
Player Version#: TiVo Roamio Plus
Plex Media Server Logs_2019-08-13_17-34-23.zip (1.7 MB)
I have a problem in which certain movies fail to play, via the Plex app on my Tivo Roamio Plus. Others play no problem. I see limited errors, all are about the device being a TiVo:
Aug 13, 2019 17:30:45.598 [0x7f1c14ff9700] DEBUG - [Now] Device is TiVo ().
Aug 13, 2019 17:30:45.598 [0x7f1c14ff9700] ERROR - Unable to find client profile for device; platform=TiVo, platformVersion=20.7, device=Roamio Plus, T6 (Series 5), model=TCD848
What I do see is the following:
Aug 13, 2019 17:28:47.844 [0x7f1c78f36700] DEBUG - Failed to stream media, client probably disconnected after 163840 bytes: 104 - Connection reset by peer
In this set of logs, it failed to play Spiderman Homecoming, and Captain Marvel, but would play Blade Runner 2049.
Any help or suggestions are appreciated.
Oh, I can also definitely tell you that SM and CM were both BluRay cuts with MakeMKV, and then run through HandBrake to MP4. Can’t recall if BR was the same or not.
