Server Version#: 1.21.1.3876
Player Version#: 8.11.0.22186
Hello, I am having an odd issue with subtitles on my Shield.
I am running the PMS off a PC (not off the Shield itself) with files hosted on a Synology box. The problem is that some files play fine, but when I select a subtitle through opensubtitles.org and try to start the file, the little circle keep spinning and the file never plays/resumes. As soon as I deselect the subtitle, it’s fine again.
The odd thing is that I have other files where I can use opensubtitles.org subs without a problem. The other odd thing is that the same files that give me problems on my Shield play just fine on the web player or my Android phone (app).
I looked through the forums, but didn’t see posts about the same issue. Anybody have any idea what the problem could be? If I were to provide logs, should they come from the the Shield or the PMS?
Thanks in advance!
