Sonic Adventure Issues
Server Version#: TrueNAS Scale ElectricEel-24.10.2
Plex Version#: 1.41.5.9522
Plexamp Player Version#: v4.11.5
After learning that Sonic Adventure was not available on FreeBSD systems, I migrated from TrueNAS Core to Scale to take fuller advantage of my Plex Pass. However, it’s been a rocky road with the Sonic Analysis.
My first issue is that after successfully processing nearly 3,000 albums over the course of several days, Sonic Analysis got stuck with 1 album remaining for over two hours. I downloaded the log (and I have very little experience with these things, so please bear that in mind) and the log showed that the analysis was 100% complete and showed no “fail” messages. I restarted the Plex application and then there were no further processes or messages, so I was hopeful that whatever was “stuck” got unstuck with the app restart.
Now when I open Plexamp, the Sonic Adventure feature appears, so I thought everything was successful. However, when I try to add tracks, it tells me “No in-between tracks found. Time to grow the library”. It does this no matter which tracks I select, even if the tracks are from the same artist. There are over 40,000 tracks in the library, so I do not believe that the size of the library is the issue here. Any idea what could be happening? I am not sure if this is helpful, but below is a snippet from the log where I tried to make a sonic path between Kiss and Avicii (log removed after final post)
Update: After restarting the server, I did a manual rescan of the music library. It started the Sonic Analysis with 30 albums remaining. I wasn’t watching it at the time, but a couple minutes later, it was already at 1, leading me to believe it dropped immediately. It’s stuck at 1 album left again. The full log is [here] (link removed after final post)
Final Update: Giving it a couple more hours after the server restart allowed it to complete the final album successfully. It was less time than it originally got stuck on, but it pushed through. The server log from the previous post has been removed. Perhaps I should have given the album a couple more hours previously? At any rate, unless the restarts did something, it appears to have resolved itself and Sonic Adventure/DJ features appear to be functioning correctly. And I’m glad they do, because these seem amazing and well worth the migration away from FreeBSD.
