Sound low on Plexamp
I’ve noticed sound on Plexamp sounds lower than in Plex Media Player or Plexweb (everything in Linux).
I’ve managed to put in the config.json the hotkeys for volumedown and volumeup, and they work, but max volume is lower (yet acceptable).
The main problem is I need to put at max level the system sounds, so, every time I have a system sound, it sounds quite loud.
I’m the only one?
Thank you for the link, @OttoKerner. I’m following right there
