Server Version#: 4.30.2
Player Version#: ** 4.30.2**
I am trying to add V - The Original Mini Series and V - The FInal Battle to my Plex set up running on a Synology DS218 with the latest version of Plex.
I have tried so many variants and re-scans of the Plex library but the season 00 is just not showing up.
Attached are the files and folders (I’ve tried with and without the release year in brackets after V).
Directory of Q:\V (1983)\Specials
08/07/2020 12:54 <DIR> .
08/07/2020 12:53 <DIR> ..
08/07/2020 08:25 940,042,980 V (1983) - S00E01 - The Original Miniseries (1).mp4
08/07/2020 09:17 699,418,175 V (1983) - S00E02 - The Original Miniseries (2).mp4
08/07/2020 11:06 763,016,565 V (1984) - S00E03 - The Final Battle (1).mp4
08/07/2020 12:33 767,502,252 V (1984) - S00E04 - The Final Battle (2).mp4
I am not sure what I am doing wrong, especially with comparing the look up with the source.
hmm… maybe it’s the Mac version of Handbrake that also adds the title of the source to the embedded metadata of the video (or there’s simply been no title in that source of yours).
Do you have other episodes of that show that show up properly?
If that’s all the episodes you got for V… have you checked if they show up somewhere else as mismatched duplicates for another show? (even though you should see some change to the “recently added” hub).
If there’s other episodes that properly show up as “V” in your library that’ll rule out a mismatch. If those specials are all the episodes you want to add and they’re not showing, Plex might have mismatched them. In that case they could show as “something else” or be grouped into an existing show of yours (showing as duplicates of the existing episodes of that show). So you won’t find them as “V” in your recently added hub.
I just added a dummy file with the given name to a playground library of mine.
That file loaded just fine and was immediately recognized as the 1983 version of “V” – all I subsequently had to do was to switch the show order to “DVD order”.
OK, so I went back a stage and removed the whole library from Plex, re-added the library using the exact same directory location for the media and the V files showed up correctly…
That’s great
Could it be you previously had the library set to be a movie or other video type library? That’d explain why the files were ignored for good…
No, it was set to TV Shows etc but I did notice the “last update was 4 hours ago”… which is odd, considering I was hammering the update library button every 10 minutes
