Split Tunneling: Plex Media Server Stops Working with Split Tunneling
Hello, I have been trying to look for a work-around where I could do some sort of split tunneling.
Software which should go through VPN: Qbittorent / SABnzbd etc.
Software which shouldn’t go through VPN: Plex, Chrome, Sonarr, Radarr and everything else.
Now the issue is that, I have tried NordVPN, ExpressVPN, PureVPN, SurfShark, TorGuard and many more. None of them have properly implemented the Split Tunneling if they have this feature.
Whenever you would run Split Tunneling, Plex becomes unreachable. Split Tunneling has to be off for Plex to work. (Screenshots attached in last)
But, is there any solution to this? Because I really need Split Tunneling.
If there is any VPN Provider or Solution which has the solution and it doesn’t have this issue? Please let me know.
My ISP’s routing to various servers is pathetic and I need to use VPN so that I could get better routing and speeds for downloading content.
Please let me know.
Thanks.
Example:
Plex doesn’t work when Split Tunneling is enabled:
Plex works when Split Tunneling is disabled:
Outcome is same for every other provider.
Server Version#: 1.20.1.3252
Player Version#:Latest (Chrome)
Plex Type: I run on Local Network. (No Remote Access Involved)
Plex Machine OS: Windows 10
Plex Pass: Yes, I have Plex Pass on my other account. I use this email for forums (everywhere).
