@JuiceWSA said:
@Canaan said:
I got same or similar problem. A TV show launched a 2nd season and decided handle it as a new Show with an additional subtitle (story continues, but it’s a new show starting with season 1 : theTVDB).
Usually, I have following folder structure
[TV Shows] / [Show Kind] / [ Show Title ] / [ S(eason)# ] / [ Show Title ( - sub Title ) - S#E#.ext ]
But since there are 2 Shows with same main story… I had to change it to…
[TV Shows] / [Show Kind] / [ General Show Title ] / [ Specific Show Title ] / [ S(eason)# ] / [ Show Title ( - specific sub Title ) - S#E#.ext ]
But Plex is always stacking those 2 Shows and can not split them apart…
But my requirement is, that those 2 Shows are connected in some way in the folder system (since I browse media using the filesystem).
And how’s that working out for you?
Not too good is it?
https://support.plex.tv/hc/en-us/articles/200220687-Naming-Series-Season-Based-TV-Shows
A Drive/A Directory/A Sub Directory/A Sub-Sub Directory/A TV Show Library/ <— welcome to a valid TV Show Library
… A TV Show Name/
…Season 01/
…A TV Show Name - S01E01.xxx
A Drive/A TV Show Library/ <---- enter pain and suffering if what follows is:
…A Sub Directory/ <— Nope - won’t work
…A Sub-Sub Directory/ <---- Not getting any better
…A TV Show Name/ <— What’s that? Plex has no idea even if you do.
…Season 01/
Share the name of this mystery show and I’ll give you a few examples of proper naming and structuring and there’s a ‘special way’ you now have to deal with TV Show Remakes - and that’s NOT covered in the Handbook. Plex wants you to find that out on your own - or by asking a Volunteer Support Guy.
All calls for a remake were previously made simply by using the name at TVDB as it’s shown:
Father Brown (2013) - for instance
Now Plex defaults all calls for Father Brown to Father Brown (2013), so if you happen to have the earlier show (Father Brown (1974) ) you have to go to TVDB, get the date (not shown in the name) and inject that into your Folder and File Names before Plex can successfully find and match it with TVDB.
Plex was sure that was going to help matters - and I would really like to have some of what ever it is they’re smoking. Apparently that will really change the universe into what ever you want it to be, instead of what it really is and I could go for a triple-heaped-hookah full of that right about now.
Hi there,
My Plex is running on a NAS, so I’ll have no “Drive” Paths…
I kinda “fixed” it by now…
I renamed the the items so Plex couldn’t match them and matched it on my own. Afterwards I moved and renamed things right.
But your input may help me to prevent this workaround.
So, those "mysterious show"s ID(s) are
http://thetvdb.com/?tab=series&id=289882&lid=7
http://thetvdb.com/?tab=series&id=321670&lid=7
I got 3 Libraries, 1 Music, 1 Movies, 1 Series
In that case, the library ‘Series’ includes 5 folders…
(there are other folders at the same level where I don’t want Plex to interfere because there are files without proper name convention and will be sorted at their final location)
- Animation
- 3D-Animation
- CGI
- Feature Film
- Stop Motion
For example, family guy goes to
(series/)Animation/Family Guy/S10/Family Guy - S10E08.ext
while “How I met your Mother” end up at
(series/)Feature Film/How I met your Mother/S01/How I met your Mother - S01E01.ext
And unlike the movies library, where something like that work pretty good…
(Movies/)CGI/Pirates of the Caribbean/1 - The Black Pearl/Pirates of the Caribbean - The Black Pearl.ext
…does not at Series.
