.srt files not showing after syncing library
Hi, recently I have issues after I had to re-scan all my libraries and then finding that my English Subs were for 85% not showing up in my movies or tv shows. Meaning I would have to manually upload over 1,000 .srt files to have them show up again.
Anyone else having issues when re-scanning or re-adding existing libraries on iMac?
Plex Server version: 4.49.2
iMac: Mid 2010; Intel Core i3, 3.06Ghz; 16Gb RAM; Mac OS Sierra (10.12.6)
I have same problem…
It started around sep/20 with an update, where my 35TB lib on the nas is connected to my Windows Plex server running on Windows server. The Plex server was looking at my files via UNC link like this \server\HD\2017\ and so on.
I had to roll back til an summer edition of Plex and connect my Windows server to the files via mapped drive M.\2017 to get it work again. Reindex all files and I had to look over all 4000 films to correct wrongly mapped films.
By mistake I updated to an newer version of Plex 2 weeks ago and now have your problem: Every time I buy a movie, rip it, find the SRT files and place it on Plex and run reindex ALL my srt files are removed :frowning:
I can go in on every film and run “Fix match” and then it is back … on 4000 films
SRT support on Plex is useless and Plex need to do something about tha stability
I found that I have to refresh all metadata for all my different folders and now they are showing up again, but still it is very annoying.
I tried that, but it did not work in my case :frowning:
I was so glad to see an solution, but… :frowning:
