Hi all, seems to be a known and commented on issue but no comment from plex/development so im making some noise.
I have a 4k HDR movie.
I play it without SRT subtitles, plays fine
I enable SRT subtitles, it starts transcoding and buffers and stutters - however it is not burning the subtitles it, it is displaying them dynamically (respond to interface coming up, subtitles move around the screen and adjust)
This is a bug in LG WebOS Plex Media Player - When is this going to be fixed?
Some people ahve reported that roll back the server version fixed the issue. I do not have the old packages for my qnap, and intro detected is too rad.
Server Version#: 1.20.1.3252
Player Version#: Latest LG WebOS
If i disable SRT, no stuttering/buffering, and no transcoding log messages.
EDIT: Im not actually sure its transcoding. im runnning this on a QNAP, it wouldnt have the cpu capacity to transcode the video and only cause the intermittant buffiering that its doing. But its certainly doing something weird that changes the experience from watching without buffer to buffering every 10 to 60 seconds.
No luck with the remuxing unfortunately (i ran it through the latest version of MKVToolNix, not sure if i need to do anything special other than run it through it)
Please see attached server logs. Let me know if any other log files can be of help.
I have the same exact problem, it’s a Plex bug, the same movie can be played without any transcoding using the LG SmartShare app, but through Plex, even if it reports that direct play is being used, the HDD is used at 100% whenever internal subtitles are selected. If the subtitle is selected through the search function of the LG Plex app, then everything works.
The LG app does not support PGS subtitles so those always have to be burned into your video. If your server isn’t powerful enough to handle this, then you will get buffering. This is a limitation of your server.
This uses srt subtitles which does not need to be transcoded.
Yes it’s true, I’m wrong there is transcoding from a PGS but I’ve never had a buffering problem to the point that the movie doesn’t start.
As for the server, I don’t risk having any problem since I have been running for 4 years on an HP DL380 G8 with two XeonE5-2630 at 2.30GHz and 64GB of ram with a 10Gb 530FLR network card with Plex, Jdownloader and MKVtoolnix the rest run on another server.
This is the first time that I have this problem.
But good for more security, I will put subtitles SRT
In my case, I have a synology NAS 1520+ that’s capable of HW transcoding with no issues.
And I want the video and audio to transcode to a LG WebOS TV. And that works fine. But if I enable subtitles (SRT), it doesn’t play.
Is it possible to have both video/audio transcoding, but the srt to only be sent to the webos client?
I really want to have video hw transcoding, audio transcoding + srt subtitles (no burning into) working
I have the same problem with SRT subtitels. When using the Plex App on my LG C9 it always buffers as if it is transcoding, but in the activity tap it says direc play and direc stream. This problem is now there for several months so I bought a Nvidia Shield TV. Sadly it isn’t perfect either. The Shield TV can’t play E-AC3 Audio without stutering. I don’t know if it is the only limitation but I will see. I WIll probably try the kodi app with the kodi addon for plex. I heard a lot of good things about this combination.
It says that it is direct playing on the dashboard but the console shows some transcoding. Stuttering in videos that are easily transcoded for other devices. I reckon that the fact that it is registered as “direct play” doesn’t even pull the resources for it to transcode optimally.
I have the exact same problem. For months! Won’t this get a fix ever?
